Fuel Filter.
Old 02-12-2007, 02:30 PM
vltnolia's Avatar
Default Fuel Filter.
Iam getting ready to change the fuel filter on my 98 civic ex and 99 civic hx. All we need to do in order to complete the install is 1) disconnect the batter 2) disconnect the firewall plate 3) disconnect the upper and lower bolts and nuts.
Am I missing anything?
Old 02-12-2007, 02:33 PM
Mario_D's Avatar
Default Re: Fuel Filter. (vltnolia)
1. Depressurize the system.
2. Have towels/rags ready to absorb the fuel.
3. Proceed with removal.
m-
Old 02-12-2007, 03:10 PM
Syndacate's Avatar
Default Re: Fuel Filter. (Mario_D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mario_D &raquo;</TD></TR><TR><TD CLASS="quote">1. Depressurize the system.
m-</TD></TR></TABLE>
Yeah that's pretty much what I said.
To depressurize just take off the fuel cap and loosen the service bolt on top of the fuel filter - fuel will spill out so have a towel on top of it.
Then have some more towels ready for when you remove the filter b/c that'll spill some fuel out as well when u d/c the lines. I recommend doing this outside oppose to inside a garage - but whatever works, gas evaporates fast.
Old 02-12-2007, 03:22 PM
vltnolia's Avatar
Cool. Thanks for the replies
Old 02-12-2007, 03:26 PM
* B A N N E D *
nicko360's Avatar
Default Re: Fuel Filter. (Syndacate)
its really easy, you can even skip the part where you disconnect the battery and use rags, takes 10 minutes max. - Nick
Old 02-14-2007, 11:22 AM
vltnolia's Avatar
I just changed the fuel filters on my 99 civic hx, and 98 civic ex. Not difficult at all. Thanks for all the help.
Old 02-14-2007, 11:24 AM
vltnolia's Avatar
I bought napa fuel filters for 14.99. good deal! Any way they came with 3 copper rings, 2 for the top and 1 for the bottom. The bottom ring I didnt use because i thought it was gooing to restrict fuel flow if the ring was put in there not properly. Plus the oem filter didnt use one, would this be a problem or am I okay?
redlinez_r_us
09-16-2009 12:02 PM
Re3irth
25
06-27-2009 06:40 AM
TMC_EF
03-22-2007 01:07 PM
Muckman
12-09-2002 01:09 PM
Quick Reply: Fuel Filter.
