FUEL CUT PROBLEMS???? HELP PLEASE!!!!!
I just did a 00 SI swap into my 96 HX coupe and im having a fuel cut problems. Its throwing no check engine because im running a chipped p28. Thanks for any help!!!!!!!!!!!!
Modified by kwazigoku at 1:56 PM 1/15/2005
1 Post
Re: FUEL CUT PROBLEMS???? HELP PLEASE!!!!! (kwazigoku)
what do you mean fuel cut?do you mean rev limiter,or the injectors aren't working?
and BTW-all caps title is stupid,read the rules noob:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">2.B. Please do not make thread titles in all caps or with symbols that will attract attention. This steers users away from the other (most likely more important) threads on the page</TD></TR></TABLE>
Chris
Chris
Re: FUEL CUT PROBLEMS???? HELP PLEASE!!!!! (TeamNextGenChris)
Everytime i step on it the check engine blinks on and off its like not getting enough fuel. Thanks for your help!
1 Post
why do you think it necessarily fuel related?do you have any stored trouble codes?
have you checked your cam/ignition timing?
does it run okay under light throttle?
did you replace all the serviceable parts before you put the motor in?
do you know if this motor ran before you put it in,or did you buy it already pulled from the car?
did your car run good with the stock motor?
Chris
Chris
harryr34
06-07-2005 01:23 PM
