fuel killswitch
fuel killswitch
i installed a fuel killswitch yesterday. it was running then this morning while driving, my car just died. i turned the switch on off then it started again. is it possible that the vibration just shook the switch? if i put it back as it was not soldering it, will it affect the fuel pump like it did today?
Re: fuel killswitch
Try disconnecting the switch and redo the original wiring to see if it works under a stock set up, rather than the switch interfering with the circuit. that will tell you if your pump or switch went TU for some reason. Just check your connections and make sure they are solid.
Re: fuel killswitch
also..some of those switches are plain junk. is it a cheap (2 dollar part) plastic switch? might want to get a better switch if this is the case.
Re: fuel killswitch
The current rating of the switch does matter, so does the wire gauge and length. Get a real switch, not from "radio crap". Solder the connections whenever possible.
Re: fuel killswitch
I installed my switch using 18 gauge wire and a switch I got from Radioshack, which I think was a 20 or 25 amp switch, I can't quite remember. It works fine. OH YES, another important question, how far away from the pump did you mount your switch. I think if its furtehr then 4-5 ft, you're going to have to use a relay.
Re: fuel killswitch
My kill switch is inline with a low current signal from the ECU before the full pump relay "main relay". Switching a high current load with a switch is stupid.
Re: fuel killswitch
maybe a feet and a half. i took out the switch and rewired the wires together without soldering. is it going to post any problems in the future?
Re: fuel killswitch
i installed a new rocker witch from radio sack 25 amp. everything's fine except for sometimes when i switch it off, and come back to the car and switch it back on, it doesn't start right away. i have to turn it off and on again to start the car. anybody have this problem? did i mess anything up?
Re: fuel killswitch
I hate it when people post install guides for Fuel Pump kill switches..sure let the Thieves roam and find out where people put them in there Civics/Del Sols,etc.
Re: fuel killswitch
you turn it off, walk away, come back and hit the switch, let the pump fully prime, then start? i made my switch turn off the ground that runs close to the drivers seat.
Re: fuel killswitch
what i do is i switch it to ACC and wouldn't hear the fuel pump whirl so i go and switch the switch off and on again then it'll start. it's not something serious, is it?
Re: fuel killswitch
Re: fuel killswitch
