front lower tranny bracket....
front lower tranny mount....
what up,
i recently swapped a b18 into my 99 ek hatch, i used hasport motor mounts (left side, right side, and lower mount) i just dont have the mount that's in the front that connects to the transmission (under the coolant overflow bottle). do i need that mount?
thanks
thanks
Re: front lower tranny bracket.... (sicones)
It helps to have that mount. It is just a torque mount, and it helps dampen the engine movement under load. You do not NEED this mount to drive your car, but, I definitely suggest having it to prevent other broken mounts.
Imperious: Mod of Valor
Re: front lower tranny bracket.... (B20 EJ6)
You don't NEED that mount, however it's always a good idea to give your motor all the physical support you can.
Re: (EKhatch219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKhatch219 »</TD></TR><TR><TD CLASS="quote">can i use that mount from my d16?</TD></TR></TABLE>
I'm guessing no. Only reason is because that mount connects your chassi (which it would bolt up to) and the other end connects to your transmission. As we know, the D and B series transmission are different, the B being physically bigger than the D. You can try it, but I doubt the holes will line up properly.
