??? Front lower control arm changing rear part with sway bar hole.?
Has anyone ever split the front lower control arm at the 2 bolts and replaced just the rear portion with sway bar mount hole. By that I mean the same ball joint to frame part is a civic DX but the back or rear of the lower control arm is changed to an EX to allow the front sway bar to attach. Anyone do this.?
Re: ??? Front lower control arm changing rear part with sway bar hole.? (DerangedEG)
https://honda-tech.com/zerothread?id=856126
Here is a diagram of the front LCA 2nd post. The part I am talking about removing is part 1 2 from the rear portion that goes into number 3. The 2 bolts can be removed from part 1 2 to allow the rear portion that goes into 3 to be replaced and allow a front sway bar.
Re: (moto27cm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moto27cm »</TD></TR><TR><TD CLASS="quote">Yes. No problem. EX,Si,GSRs will bolt right up, maybe more.</TD></TR></TABLE>
Cool that's what I was hoping...thanks.
vegaskurt
06-30-2005 09:55 AM
