96 civic brake master cylinder problem
I bought a car for cheap off a guy and when I bought it the car brake pedal would go to the floor every now and then while driving and only would always go to the the floor when making a uturn or turning the wheel all the way to the left. I replaced the brake master cylinder and bled all the brakes in the correct order and the brakes are fine now but still go to the floor only when making a uturn or turing the wheel all the way to the left, they start working again after I pump them twice. Could there be a problem with the brake booster? I checked and have no leaks either
Re: 96 civic brake master cylinder problem
Are you losing any brake fluid? The only thing remotely connecting the steering to the brake system is your brake lines, and the only way I could imagine explaining this is your front lines are leaking during heavy turns.
