Front LCA and sway bar install on EG help?
Does anyone know what happened to the FAQ with the front LCA install on an EG?
I thought i came by it before but i don't see another one. Need to install DC2 front LCA with ITR front sway.
Thanks.
Thanks.
Re: Front LCA and sway bar install on EG help? (vietfella)
To make install easier and to avoid ripping that nut off trying to remove the LCA, you can just remove the "A" part of the LCA and the leave the "I" part bolted up. I did this method because I didn't want to undo the tack welded nut.
Re: Front LCA and sway bar install on EG help? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">To make install easier and to avoid ripping that nut off trying to remove the LCA, you can just remove the "A" part of the LCA and the leave the "I" part bolted up. I did this method because I didn't want to undo the tack welded nut.</TD></TR></TABLE>
Smart guy
Smart guy
Asild
03-18-2002 04:05 PM
