Found the problem! D16y7 bottom end rattle
Old 09-23-2014, 01:01 AM
99silverslug's Avatar
Default Found the problem! D16y7 bottom end rattle
So I had a post about something ticking and rattling in my bottom end I got a new oil pan gasket and started to remove everything to get at it, I pulled off the inspection plate and a bolt fell into my hand... After some research I see that it's a pressure plate bolt. Is there anyway I can get at it without removing the transmission ? Maybe thru the top where the starter meets the flywheel? Any help is appreciated as this is my first honda
Old 09-23-2014, 01:10 AM
I never narc'd on nobody!
NotARaCist's Avatar
Default Re: Found the problem! D16y7 bottom end rattle
Uh, pressure plate bolts don't just magically fall out on their own. That said, I don't think it's possible to properly install pressure plate bolts without pulling the transmission.
Old 09-23-2014, 03:11 AM
canadaek's Avatar
If it's a pressure plate bolt you have bigger problems. Like how it got through the end of the block there is no opening between trans and engine . Does it have a 12 point 10mm head on the bolt ?
Old 09-23-2014, 04:24 AM
NotARaCist's Avatar
OP said he removed the inspection plate, which covers the flywheel, which is directly bolted onto the pressure plate. The location makes sense. The bolt doesn't.
Old 09-23-2014, 07:14 AM
^thanks lol I know it's not a flywheel bolt it's too small as yes it's a 12 point head on it, I've heard you can see them with the starter off, I just wondering if I can replace this bolt atleast somewhat properly without dropping the trans, I plan on putting loctite unlike the last person, even if I just use a wrench it's better then it not being there at all right?
Old 09-23-2014, 08:27 AM
canadaek's Avatar
Sorry I must have been sleeping still I thought it said he pulled oil pan and found bolt behind inspection plate make way more sense
Old 09-23-2014, 09:56 AM
Fish Twig
tony_2018's Avatar
OP, there is no way around it.
Blazinlow
Transmission & Drivetrain
09-26-2012 09:55 PM
kornerk12
02-15-2007 08:26 AM
FermiumHalo
09-12-2005 06:00 AM
Ej6B20
18
07-17-2004 02:58 PM
Quick Reply: Found the problem! D16y7 bottom end rattle
