Fixing cracked lip
Old 12-17-2003, 01:51 PM
fred92htch's Avatar
Default Fixing cracked lip
Long story short. I was moving my car and backed over a small culvert and the front lip dragged and cracked. It's an ABS plastic one and not cracked all the way from top to bottom, just bottom and front. Can this be repaired? Like bonded or fiberglassed on the backside?
Old 12-17-2003, 01:54 PM
ng
ng's Avatar
Might as well just buy a new, CF one.
Old 12-17-2003, 02:41 PM
simplegreenmachine's Avatar
Default Re: (ng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ng &raquo;</TD></TR><TR><TD CLASS="quote">Might as well just buy a new, CF one.</TD></TR></TABLE>
and waste money? just run to a local shop and get a new one for 50$
Old 12-17-2003, 03:41 PM
slvrcivic97's Avatar
Default Re: (MonKey Magic)
dude, I just busted my abs mugen lip in 3 peices like a week ago from sliding on ice and running the lip into a curb going like 5 mph. I used this stuff called fixit or something like that (it's super glue basically) and glued the 3 pieces together and it holds up fine until winters over. Then I'll put my cf spoon one on. But yeah, it doesn't look too attractive, but it does work. Just make sure you let the glue dry completely before even attempting to put it on.
Old 12-17-2003, 03:45 PM
Down Since Day 1
1 point 6's Avatar
Default Re: (slvrcivic97)
SloCivicHmm cracked his, He used plastic body filler i THINK. Hit em up.
Old 12-17-2003, 04:30 PM
blackSi_sd's Avatar
Default Re: (1 point 6)
just repair it yourself... someone said something about glue and body filler...use both.
Old 12-17-2003, 05:10 PM
HATCHingMN's Avatar
Default Re: (blackSi_sd)
super glue for auto
Modified by HATCHingMN at 2:27 AM 12/18/2003
Old 12-17-2003, 06:03 PM
specificcivic's Avatar
Default Re: Fixing cracked lip (fred92htch)
Pull a Red Green and use that new 3m invisible duct tape or is that too canuck for ya? U guys know who Red Green is right? or is that just another example of Canadian comedy not making it south of the border!?
LOL!
I my 's (01 civic coupe & 96 Civic hatch)
Old 12-17-2003, 07:30 PM
EG(6)SR's Avatar
My little brother borrowed the car, and came home not once but twice with a broken lip (not face, but the civic!). Its seen better days, but I've been able to fix it both times with ABS glue. I know its a bit ghetto, but I decided that I would keep it because one, it was gift from a good buddy of mines, and second it looks better then no lip and will have to do untill a get a new carbon fiber one.
You can repair it quite easily, even if its torn in two. Get some ABS plastic glue, its the sort that pumbers use. I just took it from my dad whose a general contracter, and apply and let set. It creates a pretty dam strong bond if you get the piece to stay there for a while. Remember to make sure you apply some sort of force to hold the pieces together, use a clamp, or some tape, or just something to insure that the peices hold together.
When I had massively broken lip, I layered the glue on, let it set, then came back the next day, and sanded the entire lip down and repainted it flat black. Can't tell the lip was ever broken.
Old 12-17-2003, 08:17 PM
zexdrex's Avatar
Default Re: Fixing cracked lip (EG(6)SR)
theres this stuff i use on my bike to repair fairings
it works great on that
http://www.urethanesupply.com/street.html
Old 12-18-2003, 08:36 AM
fred92htch's Avatar
EG6 SR...do you know where to buy that stuff? Home Depot or similar? Sounds like a good fix. I'm not ready to buy another lip.
Red Green rocks
Old 12-18-2003, 08:41 AM
trooper0641's Avatar
i recently cracked my mugen lip too...you cannot fix it back into perfect shape. I tried...and believe me...it wasnt pretty...just buy a new one or go with the stock ex lip like me.
Its such a hassle rolling around with a big mugen lip. It hits everything!
Old 12-18-2003, 09:00 AM
jbs
jbs's Avatar
I fixed one before. I used 36 grit on the back then laid fiberglass on it. You'll have to use boddy filler to smooth out the cracks in the front. Then paint.
Old 11-26-2004, 09:29 AM
visionw8's Avatar
poxy glue or jb weld should do the job
demian22
05-22-2008 09:41 PM
aznjay510
09-14-2006 03:45 PM
D16Z6racing
08-06-2006 05:13 PM
JDMlyfestyle
04-06-2005 03:51 PM
Quick Reply: Fixing cracked lip
