first gen B16A into '93 DEL SOL Si.. mounts and brackets?
I'm putting a B16A1 from my built CRX (totalled) into my '93 DEL SOL Si.
Do I need integra mounts or will my stock mounts work? which brackets do I need? Do I need to modify DC shift linkage or would '97 DEL SOL VTEC linkage bolt up?
One more thing, I was told my P28 ECU will run the B16A without modification, is this true? Thanks for any help provided.
Re: first gen B16A into '93 DEL SOL Si.. mounts and brackets? (jdm_vtec)
i dont think crx mounts will work i just did this swap in my car you need the hasport mounts ( EGB1) it also converts your cable trans to hydraulic. also you need the rear engine bracket from a del sol vtec (b16) i think its called a "T bracket" its black and it's the one that connects your trans to the rear mount.
What transmission do you have?
Re: first gen B16A into '93 DEL SOL Si.. mounts and brackets? (94 delsol)
i'm buying a hydro transmission for the swap.
I've been told my rear and passenger side mounts from the DEL SOL D16Z6 will work with the B16A with a rear integra bracket and a driver side integra mount
hotimportcrx
11-27-2005 09:32 PM
90civichb
06-05-2004 04:13 AM
