A few questions, compression, resistance
So I just put a D15b bottom end w/ D17 pistons in my car (picked up off a friend) so I'd have something to run the car with while I rebuild my built D16 bottom end.
Now I put everything from my motor on this block (water pump, head w/ manifolds, turbo, etc). Its all back in the car and everything is wired up.
It doesnt want to start.
The D15B was just rebuilt (according to the friend) w/ the D17 pistons on a fresh hone and new rings. It has 0 miles on it since rebuild according to him.
Now I do a compression test and I get 90-110-100-95, is spoadic/low compression normal for freshly rebuilt motors that haven't been run/broken in yet?
Also I have a resistor box wired into my harness so I can use my Peak & Hold PTE 680cc injectors. I should be able to test resistance between the 2 wires for each injector, right?
If so what should the resistance be? I'm using a stock Honda resistor box off an older civic/integra.
The Grumpiest
Re: A few questions, compression, resistance
It's probably because this has to do with a boosted setup. I think the FI forum would get you some answers. I mean I have an entry level boosted D and I'm no pro but I'll be honest and say that I don't have a clue why you would need to test the resistance of the injector wires or what they should read.
triumph_013
02-05-2013 09:23 AM
SpoolnByYou
13
01-04-2007 12:14 PM
