Few questions
Few questions
1. I'm having weird problems with my relay's or something. But whenever it is really cold out my left blinker takes awhile to come on unless I hold it down. If its hot out it works easily though.
2. Somethings up with my brakes but when its hot out and I hit them (Only sometimes) they sink all the way to the floor slowly. Im hoping this is an easy fix like bleeding my brakes or something. Because its UBER annoying.
any answers thanks ahead of time. This is my last post of the day freaking 5 post-a-day limit.
Thx in advance
Thx in advance
Re: Few questions (SparCoUSA)
Bleed your brakes for the sinking problem. Be sure you keep your reservoir full of fluid, and bleed them in the correct order (search). Doesn't hurt to over bleed too, just don't let the fluid get all over your pads / rotor because it'll eat em up.
Also is your brake fluid reservoir full to start? You might have a leak in a brakeline, but my guess would be air in your lines. Bleed em.
No idea about the electrical problem.
Re: (94hatchling)
The other day when I was checking my CEL codes I jumped the wrong plug and now my heater/ac fan won't come on. I checked all my fuses. They look good. Any ideas?
Re: (SparCoUSA)
I found out what my problem is after I got home and looked at my manual. I blew the blower relay located under the hood on the passenger side.
I have a leaking oil pan now. I guess that's no surprise after 231,000 miles. Just more work.
As far as your not getting any heat; have you looked under the dash on the passenger side to make sure that the heater linkage is connected so that water can enter the heater core?
