Feeler Gauge Question for B16a EM1
Old 12-10-2011, 03:21 PM
KrazoMike's Avatar
Icon2 Feeler Gauge Question for B16a EM1
got a SIRii head from HMotor and it didn't have the cam gear attached. So I have no clue where TDC..I want to say when the cam gear is pushing down on #1 rocker arm that it is TDC.. (but I'm so new at this I don't want to try anything just yet...) I can feed a .009 mm through the cam/arm gap already so I'm guessing thats bad... OR does it even matter since the head isn't even on the block? I have the Helms that everyone has, is there a certain section that lets you find it when you have this problem?
Thanks
Old 12-10-2011, 03:28 PM
Former User's Avatar
Default Re: Feeler Gauge Question for B16a EM1
Why not wait until you have a cam gear to set the valve clearances?
Old 12-10-2011, 03:48 PM
KrazoMike's Avatar
Well when I attached the cam gears do I just turn the gear to the TDC position and go ahead?
Old 12-10-2011, 03:52 PM
Texas4door's Avatar
If everything is already torqued down correctly on the head, yeah, it should be ok to do that....just a heads up that it's a pain in the *** to turn a single cam gear by hand, much more so dual cams that must be in sync with each other or else it all gets thrown outta whack again.
Old 12-10-2011, 04:49 PM
KrazoMike's Avatar
Well If I do this is this going to be a for sure way to know if my cam gears are TDC. I mean just by lining up the TDC marks doesn't necessarily mean that my cams are TDC does it? (meaning that theres some specific way to line up the cam gear to the cam to guarantee TDC with out having the head on the block!)
Thanks
Old 12-10-2011, 04:54 PM
morbius18's Avatar
There is a keyway on the camshafts and camgears. You can't mess it up. I got an extra pr3 stock gear ill give you if you pay the shipping.
Old 12-10-2011, 07:15 PM
KrazoMike's Avatar
Sweet! I ordered the gears last week they should be in this week i hope. Thanks for the offer though!
clindberg86
08-20-2013 05:46 AM
loudassVTEC
09-10-2007 01:48 PM
Soccerking3000
12-30-2004 07:08 AM
Quick Reply: Feeler Gauge Question for B16a EM1
