power window and power door lock conversion
How do you do a power window and power door lock conversion???
is it hard to convert from manual to power everything and wat about the sunroof??? wat is the average estimate on an sunroof conversion???
Modified by 00_whytehatch at 9:03 PM 6/1/2005
Re: power window and power door lock conversion (00_whytehatch)
Power windows/locks is a pretty simple, but time consuming conversion. I did this a few months ago. Had to strip the whole interior to lay down the new harness, install and adjust regulators. I dont know how well you are at working with your hands, but if i were you i would give myself a couple days, just in case you run into lil snags. For ex. After i completed it, only my passanger window was working....after a few hours of cursing and diagnosing the situation, i discovered the circuit board on my driver side switch was fried. So a weekend should do it! Anyways...good luck with the conversion!
sorry no advice on sunroof....
Modified by ballplayer at 5:25 AM 6/2/2005
Re: How do you do a power window and power door lock conversion??? (00_whytehatch)
I'm going to be doing my power window/lock conversion soon...hopefully. Got everything...just need free time/days to work on it. But hopefully these links helps.
https://honda-tech.com/zerothread?id=1065575
http://repo.jackmoves.com/albun42?page=1
Re: How do you do a power window and power door lock conversion??? (methos713)
i jsut did a power lock set up on my car last weekend... i didnt go and get teh stock EX doors and all the garbage either.. insted i got a central locking unit from AutoLoc. Its a great system... it will lock and unlock all door at the same time. for ex. when i unlock my door by putting the key in the door, it unlocks the passenger side also. and they make a 4 door kit also. the actuators are stronger than **** also. the other nice thing about it is that on the central box there are two extra wires to add remote locks from a alarm for example... The same company also makes a power window set.. check out the site.. I Love my locks.. one of the best things i have done so far!
http://www.autoloc.com/
