FastBrakes rear kit
FastBrakes rear kit
what else is needed that isnt in the kit to slap on rear disc brakes? check out fastbrakes.com and its under rear big brake kit. its only 199. but what else is needed?
BTW-im talking about replacing the stock rear drums with the rear disc kit
[Modified by deviant1, 1:59 AM 7/25/2002]
Re: FastBrakes rear kit (BigZ88)
im running the big rear kit on my 93 Civic Si
its a quick 1 hour bolt in job and matches well with my 4 lug ITR fron setup
Im going to go 4 piston up front and eventually get a 2 pistons rear caliper setup
I highly recommend it as its already saved my car twice at the track
it also eliminated the wicked front end dive the car had braking at speed into a corner
Re: FastBrakes rear kit (deviant1)
You'll have to have rear disks in order to just bolt this on. If not, the what you need are the trailing arms off a higher trim class civic like yours that had factory rear disks.
it uses stock calipers with new brackets and larger rotors
you would need rear disc already , or call brian and ask what other pieces are involved
you will also need to run 15" wheels to clear the 11+" rotors
Yeah, talk to Brian, he has hook-ups if you need to convert from disk to drums. When I bought my set, he was able to get me the e-brake cables, and rear calipers for fairly cheap.
Future Texas Boy
Re: FastBrakes rear kit (Guardson3r3)
You can purchase the big rear kit from Brian if you already have rear discs, it`s very straight forward in regard to install. If you have drums, he can get you everything you need for the conversion.
Btw, I sell Fastbrakes now. My pricing is really good
Ryan
Ryan
JunY
11-10-2005 10:39 PM
