Fan problem...
Fan problem...
We did a 95 GSR swap into my 92 VX and for some reason the fan wont kick on... everything is hooked up... all the fuses r still good... it just wont turn on... i mean it really isn't a problem when i'm driving but when i'm stopped for a long time it starts to heat up... what can i do to fix it???
Re: Fan problem... (EGizzleC1)
it's either the fan switch relay or the thermo switch.. the cooling fan switch that completes the circuit at a set temperature.... assuming all your wiring is complete....check these two items
Re: Fan problem... (eg6beater)
on the older hondas, you can jumper the fan switch (i think honda calls it the CTS = coolant temperature switch). to make sure everything works from that point forward. try that out first to make sure everything in that path works ok.
truejdm86
11
05-02-2011 06:33 AM
Lloyd Xmas
04-14-2010 09:21 AM
