Exhaust help
Exhaust help
I've got a 96 Civic Hatchback with a B20z2 block and a integra GSR head. I heard if I get the civic's mid pipe and axle back that it will bolt right up to the header. Can someone confirm this? Also I'm having an idle problem. 3/4th of the time when i start the car the idle jumps from about 200 RPM to 700 RPM and sometimes its a steady idle at around 800-900 RPM. When i drive and try to punch it in either 1st or 2nd gear the car jerks like your jamming the throttle in and out. Can someone help me?
Re: Exhaust help (VietSpeed)
It should bolt up the pipe in about the same place. Worst you have to do is either add a section or just adjust the positioning a little.
mjshealy
20
06-26-2009 12:33 PM
