Exactly which parts swap over from DC to EG?
i've done a search on this site quite a few times, just havent found enough info...or else i wouldn't ask...are the exhausts swap-able? all SUS parts? you guys get the idea...hopefully i'll get enough info so i wont bug you guys again!
thanks again!!
thanks again!!
Re: Exactly which parts swap over from DC to EG? (Slo_Teg)
Mike... I'm 99.9% sure the exhaust is not swapable. The suspension stuff like springs and shocks are swapable (except for the ITR). But I am kinda iffy on the rear swaybar. I don't think the EG has holes on the lca for the swaybar endlinks so you'd have to swap the lca's off a teg too. Can someone confirm this info? Thanks
Check this link out for some more info on the swaybar deal.
http://hybrid.honda-perf.org/tech/ITRon5G.html
[Modified by HENRY, 1:24 PM 2/7/2002]
Re: Exactly which parts swap over from DC to EG? (HENRY)
you will need the Teg LCA for the sway bar swap, since the civic one does not have sway bar hole on them, and ofcourse the reinforcement plate is recommended if you go with the Type R sway bar
as for other parts, the mid-pipe of the DC will fit, but the back section will need to be modify, might fit a coupe without though(not too sure, i am a hatch guy), pretty much anything is swapable, i have an EG with pretty much only left that is still an EG is the shell and body parts, suspension of DC2R, eng off DC2, seats and dash as well..........have fun putting DC parts into civic
HENRY: unless i can find a way to grab all my rear SUS stuff, that bar is yours for the taking...
Re: Exactly which parts swap over from DC to EG? (DB8)
depends which "eg" you are talkin about. The exhaust fits fine from DC to a 5th gen coupe. Hatchback it won't however. I'm pretty sure the midpipe fits all of the above from any car fine however. Suspension stuff, well someone already answered it
vp rsvmille
04-12-2004 08:56 PM
Mischief_EG
02-10-2004 08:17 PM
AThiker
06-16-2003 03:37 PM
