?: EX and SI front LCA the same on EK's?
i searched...
is the 96-00 civic EX civic front LCA, the same as SI front lca?
if i want to put on a SI front sway bar, will it fit onto the EX lca?
thanks for the help
Modified by jdmEL at 9:35 PM 3/19/2004
thanks for the help
Re: ?: EX and SI front LCA the same on EK's? (jdmEL)
the si's are different thant the ex ones if you want to run a si front sway bar u have to use the si lca. The rear lca's are the same but the front is different.
I think the si come with 26 mm front sway bar and the ex comes with 22mm. Or is it the ctr that comes with 26mm? All i know is the lca's are different
Different. I had to change forks, honda gave me a EX fork. It didnt fit on the Si LCA, went back, got the right part and it fit.
So EX LCA are different than SI's.
Yes, I can confirm this. The front LCAs, forks, and sway bar are different. You need the Civic Si front LCAs and forks to mount the Civic Si 26 mm sway bar.
whitelightning
02-21-2006 11:15 AM
Takeoff
10
12-21-2003 06:59 AM
IDriveHonda
07-17-2003 04:40 PM
