EX knock sens. with P72??
I know I can get a sohc vtec knock sensor for cheap. The question is, will it work with a P72 setup?? Are the 2 sensors by any chance technically similar?
I believe so, my friend wired in a knock for me in my dx civic, which he had to run it from the harness, and I was runing a p72 ecu at the time and I did not get a CEL for knock , my b16 came with a knock, im pretty sure the gsr does
Re: (Shaun)
Do you think the plugs are the same? I'd rather not have to hack on my GSR harness, but if I can get an EX knock for $20, I'll make an exception
Re: (DexterThEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DexterThEG »</TD></TR><TR><TD CLASS="quote">Do you think the plugs are the same? I'd rather not have to hack on my GSR harness, but if I can get an EX knock for $20, I'll make an exception</TD></TR></TABLE>
im 80% sure they're all the same...
Re: EX knock sens. with P72?? (DexterThEG)
Wierd, I didn't think EX's had knock sensors since they run P28 ECU's and didn't require one? But anyway, I'm running a P72 on my B16A and I think the knock sensors should be the same since it's just one wire.
Re: EX knock sens. with P72?? (Jonny G.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonny G. »</TD></TR><TR><TD CLASS="quote">Wierd, I didn't think EX's had knock sensors since they run P28 ECU's and didn't require one? But anyway, I'm running a P72 on my B16A and I think the knock sensors should be the same since it's just one wire.</TD></TR></TABLE>
96+ d16y8 (ex) have knock sensors
Re: EX knock sens. with P72?? (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">
96+ d16y8 (ex) have knock sensors</TD></TR></TABLE>
Word, that's what I figured. It's an OBD2 thing hehe
Word, that's what I figured. It's an OBD2 thing hehe</TD></TR></TABLE>
and if its an obd2 thing like you said, then its NOT a p28 ecu!! p28 does not look for knock sensor...
stockegsix
05-11-2003 10:17 PM
