Engine won't start after driving in heavy rain.
Old 01-17-2010, 01:27 PM
Rustang's Avatar
Default Engine won't start after driving in heavy rain.
Hi Folks,
I have a 94 v-tec civic with 200k on it. It has rained really hard here a couple of days. The car ran fine in the rain, but today, the day after, it won't hit.
This has happen once or twice before after a few days of very very damp conditions.
What might be getting wet? Any ideas? thanks.
Old 01-17-2010, 01:56 PM
pwnstar's Avatar
Default Re: Engine won't start after driving in heavy rain.
sounds like it might be ur wiring harness, go out tonight and try and start the car or when it dose start at night take a spray bottle and spray around the motor if it looks like fireworks u need a new harness or look for a wire exposed
Old 01-17-2010, 02:08 PM
Rustang's Avatar
and spray water on it....?
it's tryin to start but won't. I smell gas now. I up the hood up to air it out, and I'll let it sit a while and get un-flooded.
Old 01-17-2010, 02:09 PM
BoostThisMS's Avatar
make sure that the inside of the dizzy cap isnt wet.
Old 01-17-2010, 02:21 PM
pwnstar's Avatar
yes water lol a little mist woulnt bother it, but now that u say that sound like it may be flooded but u say it happens when it rains i dont think the rain will caust it to flood. will it even crank? wait till it runs and try and mist it and see if you see a littl spark mainly around the distributer ur seal around the cap on the distrubter might be broke and letting water in
knightsef-eg's Avatar
change your cap and rotor and see if that works.... happened to me
any moisture in there can cause that problem
Old 01-17-2010, 02:47 PM
Rustang's Avatar
it doesn't look wet, although there's water on top of the engine block. I must of run through some puddles.
The rotor tip looks pretty worn though?
Old 01-17-2010, 02:59 PM
if its worn down id recommend changing it ... you might not be getting proper contact between the rotor and cap
Old 01-17-2010, 04:20 PM
Lambo123's Avatar
x2. Once moisture gets inside, it starts to cause problems.
Old 01-17-2010, 04:25 PM
Rustang's Avatar
Dry as a desert in there. I guess the moisture is hiding somewhere else. It'll be running again in a day or two.. :-/
Old 01-18-2010, 05:47 AM
Rustang's Avatar
Now it is hitting, starting, but it won't keep running. I know it's not fuel because I smell gas after trying it for a while. Maybe a shortage somewhere?
Fudge. This isn't my usual problem. Looks like a trip to the mechcanic.
edit: I sandpapered the contacts inside the cap, very lightly. Did I mess it up?
Old 08-14-2010, 03:41 PM
Mearth's Avatar
Did your problem ever get resolved?
I also live in the South, and have recently had the same problem with my 95 V-tec Civic. Seems like it's a pretty common one.
It's been wet here for 2 days, and my car won't start.
I can't get my distributor cap off to dry it out/replace it because the bolts are stripped. Ugh.
Old 01-07-2012, 04:01 PM
Rustang's Avatar
Hey Dude,
Thanks for replying.
Yeah it did. I am in technical school so I took it to the shop guys for a timing belt change.
They replaced the plugs also, and said the gap was way off on the old ones. It has cracked like a champ since then. I hope that is all that your problem is.
Old 01-07-2012, 10:56 PM
Simplypinoy's Avatar
Coil goes bad once it gets wet.
Narao
14
10-07-2011 07:25 AM
B18 CYA
02-29-2004 01:39 PM
NiCkArInO
04-14-2003 05:04 PM
EGHatchy
07-11-2002 11:24 AM
customx_
06-06-2002 11:17 AM
Quick Reply: Engine won't start after driving in heavy rain.
