engine swap info please
i have a 93 del sol si canada version , it came stock with a 1.6L sohc non vtec , now i want to know if i put a d15b vtec is it a direct swap ex: axcels and tranny fit , will i have to wire a ecu ? and i also would like to know am i losen power with this swap even though i`m going vtec ? info please
Re: engine swap info please (iron_man)
it should fit right in it its obd1 obd0 ones come with cable trannys, dizzy, ect. and the only thing you need to do is get a ecu and wire the vtec.
Re: engine swap info please (DannisEG6)
would i be better to go with a jd zc sohc vtec instead i`m gonna get one of the two i just want to know witch one would be better ex more hp, and easyer swap
I thought the si del sol came with the vtec d16z and the S had the non vtec, of course there was the vtec labeled del sol that that came with the b16. In that year of car the valve cover will not be labeled vtec. Dead give away are the spark plug wires on the front of the valve cover and the oil fill hole on the right rear corner of the cover?(when looking at the front of the motor) if so you have the d16z.
Re: engine swap info please (instructor74)
As instructor said, if you've got a 93 Delsol Si, you riding a D16Z6 SOHC Vtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 »</TD></TR><TR><TD CLASS="quote">I thought the si del sol came with the vtec d16z and the S had the non vtec, of course there was the vtec labeled del sol that that came with the b16.</TD></TR></TABLE>
Re: engine swap info please (canada del sol)
here this is the exact car i have witht he same engine if you care to check out the link i`m writting on behalf of iron man damn only 5 posts
http://www.autoland.us/~jimmy/...i.jpg
some one please tell me what this enigne is please
d16z6 sohc ???
d16z6 sohc ???
A few other things I forgot to mention. 1: there will be a stamp on the engine block about 1/2 way down the block right where the trans bolts up( you might have to degrease this area to read it. it should have the marking D16Z stamped in it.
2: look for the vtec solenoid in the rear left hand corner of the valve cover
first photo is the Valve cover for a vtec motor
http://www.hondaautomotivepart...COVER
#10 is the vtec solenoid
http://www.hondaautomotivepart...82%29
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by canada del sol »</TD></TR><TR><TD CLASS="quote">here this is the exact car i have witht he same engine if you care to check out the link i`m writting on behalf of iron man damn only 5 posts
d16z6 sohc ???</TD></TR></TABLE>
You have the d16z6 sohc vtec
well the pic in my last intry is the same as what you should me so i believe it would be a d16z6 but i`ll check the stamp its just cause the car is an si but its not marked and if its v-tec well i didnt know , lol its my first honda . but i thank you alot and now i`ll try to find a new motor
I have to change it cause i lost my oil pan bolt and it seased my motor so now i have no choice it came out while i was doing about 180km down the high way , and the real bitch about it is that i only had 156000 km on it, now i am looking for a good swap with out paying a whole **** load. any sujestions on what i should do and not have to pay a whoel bunch???? i`m open to anything just dont have the cash to pay for it lol
civicminded93
07-08-2008 06:21 PM
GSR_deLsOL
05-04-2004 10:52 PM
Slammd Sol
12-27-2003 08:52 AM
Sterling
12
07-17-2002 06:12 AM
