Engine Really Bogged Down! Any Help Please?
Old Apr 13, 2006 | 04:58 AM
funk2244's Avatar
Default Engine Really Bogged Down! Any Help Please?
I have a 93 honda civic with a JDM d15 engine. I had a broken throttle position sensor on my throttle body so i changed the throttle body out on the engine (cause tps sensor is mounted to throttle body) and used the same map sensor that i was previously using. I also installed a new air filter in the car.
When i restarted the vehicle it is running horrible! It has the worst air/fuel mixture and is completely bogged down. So i shutdown the car and adjusted the idle and idle screw the get the correct air and idle level. This helped some but the car is still really bogged when i drive it and give it gas at first. It really hesitates. It is throwing 3 different check engine lights, 3 (Map Sensor), 14 (EACV) and 43 (Fuel Supply). This is no surprise since these are all things related to my problem. But they all can not be bad! I could really use some help since this is my daily driving car! Thanks Everyone!
Old Apr 13, 2006 | 07:53 AM
funk2244's Avatar
Default Re: Engine Really Bogged Down! Any Help Please? (funk2244)
bump
Any ideas anyone?
Old Apr 13, 2006 | 12:28 PM
Ding's Avatar
Bump cause I want to know too.
Fnix
May 14, 2012 08:21 AM
aasaa666
Jun 29, 2008 08:13 PM
rscawley
May 26, 2005 04:00 PM
homeskillet
20
Jan 10, 2005 02:28 PM
gavhowe
Apr 30, 2003 03:10 AM
