Engine Problems
Old Jun 18, 2009 | 03:43 PM
Novtec4u's Avatar
Default Engine Problems
We just installed a Z6 in a eg 4 dr and it sounds like the starter is just spinning, we are getting fuel. The cam isnt turning though, almost like the starter isnt engageing. We pulled it out and tested it and it works fine. But when we put it in , it sounds like the starter just spins freely and wont crank the motor. Any ideas?
Old Jun 18, 2009 | 04:25 PM
D16SiHatch's Avatar
Default Re: Engine Problems
did the bendix gear pop out like it should when you tested it?
Old Jun 18, 2009 | 04:49 PM
Novtec4u's Avatar
Yes the bendix did engage out and the gear spun.
Old Jun 18, 2009 | 05:02 PM
shogee's Avatar
have you looked at the ring gear? when you take out the starter shine a light into the hole and look at the condition of the teeth, could be worn and causing the pinion to not engage a trick would be to turn the crank shaft so an unworn gear would be ready to enagage when you crank over. but you could have the wrong starter too
Old Jun 18, 2009 | 05:08 PM
Novtec4u's Avatar
the teeth look good. I dunno what it could be lol.
Old Jun 19, 2009 | 04:50 AM
shogee's Avatar
just a suggestion but i think you might have the wrong one, it was a swap right so the new starter came with the motor and tranny or you just swapped out the motor?
Old Jun 19, 2009 | 06:16 AM
Novtec4u's Avatar
swapped out the motor, its a auto btw.
Old Jun 19, 2009 | 06:18 AM
sp00ledbseries's Avatar
well hello Fellow michigander. Did you check the timing belt to see if it was snapped. When they snap the motor spins fast.
dominate9
Jan 16, 2009 04:32 AM
Root of all Evil
Apr 2, 2008 06:47 PM
lhd dc2
Feb 1, 2004 12:04 AM
GQ 05YellowEVO8
Aug 12, 2002 07:08 PM
