Engine Overheating Mystery
Car: 2000 Honda Civic EX, 1.6L 127 hp I4, 4-Speed Automatic Overdrive,
Problem: My engine is overheating. Whenever I drive in stop-and-go traffic for 30-45+ minutes my car starts to overheat -- in cold weather, hot weather, with the air conditioner on or off, with the air vent on or off (although, I’ve noticed that driving with the air vents on the blue/cool setting will make the car overheat faster than if I dive with the ac on).
Additional Info:
The temperature gauge will almost immediately return to near-normal levels upon turning my heater on. The car doesn't overheat with freeway driving.
My timing belt was just replaced. I have no blockages in the hoses. The hoses are new. The thermostat was also just replaced. The radiator has been flushed. The coolant mixture is balanced to the correct levels and does not fluctuate when my car overheats. My oil levels do fluctuate, however: when my car overheats, the oil levels drop. I don’t have an oil leak, nor is their any sign of water mixing with my oil (i.e. a murky gray film or color on the underside of the oil filler cap) nor does my car begin to smoke or let off steam when it overheats.
The fan seems to be working (when idling, the car will heat up, but the fan will turn on when the temp gauge climbs about to the mid point -- cooling the engine back to the normal temp. However, when I drive in stop/go traffic, the temp gauge climbs to the highest point, and will only drop once I turn on the heater on full blast), but my mechanic still thinks that my fan switch may be the problem. I just had the 100k tune-up.
Knowing absolutely nothing about cars, I asked my mechanic about the possibility of a blown, cracked, or otherwise damaged head gasket (which seems to be the consensus diagnoses in other forums dealing with similar issues) -- he scoffed and said that wasn't the problem. Hopefully, he’s right. That would be a huge kick in the pants.
Anyone have any idea why my car is overheating?
Thanks.
Additional Info:
Thanks.
Re: Engine Overheating Mystery
Additional Info:
Thanks.
Additional Info:
Thanks.
i would start by checking yoru coolant level. reason being is you just replaced some things and it is very possible that you have some air in your cooling system because of this.
check the radiator for fullness as opposed to the coolant resovoir.
from there i would run the car (from cold) with the cap off until the vehilce wamrs up (cap still off). as soon as the fan does come on start checking tempature indiffernces....touch both the lower and upper heater hoses to see if they are about the same tempature. post what you find otu from this.
with the cap still off look for bubbles from teh radiator... bubbles are a possiblitie of two things...either air is in the system or your head gasket is blown. start with bleeding since that is the easiest of the two.
Make sure your head gasket is good this is a given for a car overheating...
and check your fluids, it could be you have a leak and ur not gettin enough coolant
JaguarS4R
Honda Civic (2001 - 2005)
12
02-28-2010 04:12 PM
tintin11
02-14-2007 11:41 PM
2000, airconditioner, car, civic, climbs, engine, fit, gauge, go, honda, mystery, overheating, stop, temperature, traffic
