Engine mounts / engine position
Would there be something comparable to a 'ride height' for the engine similar to the proper height at which to apply final torque to suspension bushings? Engine mounts are just engine suspension bushings right..rubber, through bolt...
Re: Engine mounts / engine position
Not really, no. The reason for torquing down suspension parts at ride height is because of flex and movement. Just replace the mounts one at a time. If you're doing a swap, it really doesn't matter.
No...but if you take off the T-Bracket on the back of the engine/transmission, keep of the bolts loose before you torque them down. If you put one bolt in at a time and tighten each down, you would get them all to line up
spontaneous ep3
01-03-2005 11:24 PM
