Engine hesitation
Engine hesitation
hey guys, need a little help with my car. its a 93 hatch with a d16y7. the car recently began to have some problems. when i come say, around a corner at low rpms(1200-2000), and give the car gas, it hesitates and feels as if someone is pulling it back. then it just revs out and jerks ahead and is fine. seemed like it was starving for gas, and my milage went way down this week, although i dorve the same amount. i thought it could be the fuel filter, so yesterday i changed it and bam, problem solved. then today, it starts doing the same **** again. is it possible i have some bad gas? i have heard it can happen, but not often. i really dont know what else it could be
thanks for the help
thanks for the help
Re: (ek4h)
ill try that out, the only reason i dont understand the problem is because i put the new fuel filter on yesterday and the hesitation was gone. now all of the sudden its back.
thanks, anyone else have experience with this issue?
Re: (ek4h)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4h »</TD></TR><TR><TD CLASS="quote">check you injectors and might need to be cleaned out with some injector cleaner bro </TD></TR></TABLE>
use Lucas injector cleaner, a whole bottle per tang is what i use, and it works great, i use injector cleaner every1,500-2,300 miles i know it's not recommended but i do that to stay on the safe side
Re: (alex_s817)
but since you live out west if i were you i'd actually use Stinker gas, thats what me and my homeboy's run out there, it's the best gas and i use shell here in wisconsin it's the same gas but, when im back out there in idaho stinker is the only way to go.
Re: (Projekt_2nr)
sorry i have never even heard of that. i think i got the problem fixed though, tried some new plug wires from a friend and it fixed the problem. tomorrow im going to get new plugs and wires, and ill post up the results
bk7794
13
05-08-2012 04:46 PM
