engine help???
engine help???
ok i have a b16a and the two middle clnyders are leaking from the rings i did a dry compression test it was 175 80 125 187 so i did a wet compression test now its 210 160 125 206 then we did cynlder leak test found leak in rings now what do you think i should do sell? fix just rings or go with ctr pistions and new rings? but if i do that will i need to do crank and rods and all that or is it strong enough if i do keep it its all motor just to let you know im not turboing it or nothing oh by the way i have just spend 2k on drivetrain componets so what should i do??/
