Engine dies when it gets to the normal temperature
I just replace the cylinder head gasket and when i start the engine it's normal, but when i start to drive and the temperature gets to normal is not that often but the engine starts to die like if it was working in 3 cylinders, but when i increase the rpms the engine gets normal... I need some help...
Re: (1992Si)
where is the igniter located??? And now i think is the timming 'cause i move the distribuitor and it work better but when i'm parked the temperature goes up and qhen i accelerate the temperature goes down.. I need help...
Re: Engine dies when it gets to the normal temperature (zemogregor)
sounds kinda like it is idleing way down and getting an erratic idle. I would make sure your colant was bleed properly and your ignition timming is set right.
nicklp60452
07-14-2008 02:53 AM
ludesrv
13
04-13-2007 08:29 AM
