engine compression
you can do it yourself. when you look at your motor, there is a screw under your distributor, you gotta pull the whole thing off, and theres a bight pink screw you have to turn it 4 turns clockwise, while turning the blue screw next to it 3 times counterclockwise. but remember when you do this, you have to take your #1 plug and put it on the #4 the 4 on the 2, the 3 on the 1 to make it run right. also you will need to run 120 octane fuel so you dont have a knock.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr »</TD></TR><TR><TD CLASS="quote">you can do it yourself. when you look at your motor, there is a screw under your distributor, you gotta pull the whole thing off, and theres a bight pink screw you have to turn it 4 turns clockwise, while turning the blue screw next to it 3 times counterclockwise. but remember when you do this, you have to take your #1 plug and put it on the #4 the 4 on the 2, the 3 on the 1 to make it run right. also you will need to run 120 octane fuel so you dont have a knock.</TD></TR></TABLE>
yeah and if he flips the motor upside down it will work too!! he can mount the axles and tires through the hood
raverx3m
Jul 15, 2013 06:11 AM
dohcter g
17
Mar 23, 2005 07:47 PM
mjrage
12
May 28, 2004 03:20 PM
