engina vibration during acceleration on second gear
My 93 DX HB (No mods) has an engine vibration when I accelerate on second gear.
On other Honda engines, this can be caused by a balancer shaft out of adjustment, however, in the 1.5 engine, I do not believe that there is a balancer shaft,
I was thinking that perhaps this is a bad engine mount.
Anyone has seen this before? Any suggestions?
The car idles very smooth.
Thanks
Thanks
Re: engina vibration during acceleration on second gear (deepnite)
I haven't noticed it in first though, and I tested the clutch recently taking off on 2nd to see if it would slip but it was fine.
Thanks for the info.
v
v
Re: engina vibration during acceleration on second gear (vrrodri)
look mine did the same **** when i did my swap. it did it because my axles were ****ed so its yur axles. thank you please drive thru.
________
DODGE RAZOR HISTORY
________
DODGE RAZOR HISTORY
is it more noticable when you turn? mine would vibrate when i was accelerating and it became more noticable when i turned. turned out to be the axles, hadda replace em
Re: engina vibration during acceleration on second gear (splayed)
ummm....this maybe dumb but do you have a tach? because you might be shifting too early...hehehe
It does it when pulling straight as I drive away, hmmm, the axles...I had not thought of that, there are no cv joint tears or anything. I guess I will have to check that out.
Thanks to all for you advice.
v
v
94_DC
14
11-10-2008 05:58 PM
Lx2.2accordingly
10-06-2005 11:02 PM
5 Skware
08-28-2003 05:12 PM
