emission problem help
my girls car fail emission for c.o every thing else is fine. the car is a 94 ex sohc the.. c.o is 1.92 and the law is .97 does any one how to bring it down..for some reason i think that the car is off timing..thanks for any help
Re: emission problem help (silver ek)
using the search is good. Its been covered a bunch of times. Dump a bottle of "Guarantee to Pass" and take a nice drive. Give it a couple good WOT starts to heat the cat up then good right to the ref.
These things will help each time you take a smog test.
Change your oil
New air filter
New plugs/wires/cap/rotor if worn.
run a fuel system cleaner a week or so befor the smog test. Techron, or BG fuel system cleaner*(available only at car dealers. contact BG to find a supplier close to you)
Hope this helps
Change your oil
New air filter
Hope this helps
zipoton
10
03-06-2008 08:09 PM
