Cluster,Speedo, Engine Temp, tach and turn signals not working!?!?
I was leaving my house today and all of a sudden my cluster just went out
clock doesnt work nor does everything i mentioned above
the light comes on and everything but im not sure
i checked fuses. and im pretty sure its not unplugged cause the lights and the high beam light work
what could it be?
what could it be?
Re: Cluster,Speedo, Engine Temp, tach and turn signals not working!?!?
you've got lights but no turn signals? If so, it could be a worn out multi function switch. My signals went out and it was due to that. Not sure aboutt he cluster though, good luck
i would double check the fuses .......got pulled over when the speedometer,turn signals ,everthing on the instrament pannel went out...it took three times of trying to track it down...sorry i don't have any other ideas to what it might be.......
figured it out
it was a blown back up light fuse
so simple yet it made everything go bad
now if anyone encounters this problem they know what is it
spooncivic1
12-07-2006 08:53 PM
EGTeK
03-26-2003 10:52 AM
