Electrical Problems
Electrical Problems
Ok well i was driving my car andd when i almost got ot my detination i hear this noise. It would do it randomly annd when the noise started my tach would flicker. So i drove i to my destination and turn it of. Then i go to turn car on and i see smoke and it flickers again and then stop doing it so i drive a litle more. Next time i get in my car abot 20 min later i trn car on and it suddenly dies on me and see smoke. After that car wont start/crank just does the beeping noise af if key wasnt in the on possition and none on the lights come on( the ones that turn on when u put it on on). And my alram also dosnt work? Any suggestions?
thanks
thanks
Re: Electrical Problems (baPES)
smoke from where?
whats the voltage at the battery? alternator plug and wiring ?
my money is on the alternator getting fried and possibly blowing some fuses. check the connections and fuses.
check the manual:
http://carfiche.com/manuals020/cars/
check the manual:
who installed the alarm? if it isnt alternator (or anything else under the hood) then i would start there. also is there anything else wired into the car that isnt factory?
Re: (baPES)
a bad alternator would cause a dead battery which would in turn cause alarm not to work. but smoke from under the dash/steering column sounds like something is shorting out. i would check if there are any burnt or melted wires, and check any wires that look tapped into.
IntegraFroggie
06-24-2004 05:49 PM
