ek motor swap
ek motor swap
im thinking about possible motor swaps for an ek im leaning towards a b16a can you guys help me out and tell me what i n eed to do to so the car is ready for a swap, and what i need to upgrade so the motor will function perfect? thanks in advance
diconnect shiftlinkage, remove both axles, disconnect header, un plug entire engineharness, drain the radiator, pull off all coolant hoses, pull a/c and p/s pump, unbolt all 5 motor mounts, and disconnect the clutch line and your ready to pull that motor!
look for an engine that is the same year obd, and you should be able to plug all the factory harness and wire up for vtech. or if it comes with one use it.
if you got the extra cash, i would get the lsd(limited slip diff). helps for cornering and accel, but u should look into a b18b instead. torque owns.
and down the line you can look into an ls/v. these are my plans
a lot of people say that ls vtec isn't reliable and always breaks down. is that true?yeah the b18b does have more torque but doesnt have v tec and thats why i love haha
does anyone have info and good combinations of different motors or experiences with different motors? it'll be really helpful in my decision thanks.
* B A N N E D *
I dont know dude. it sounds like ls/vtec is a b it outta your league.. but a b16a wouldnt really be that big of an upgrade for that car. If your going to do the swap man think of something other than that. that came in old SiRs and CRXs get a b16b and youll definatly be happy. or an H22 but i think its a bit more work. good luck
Re: (Malakai)
The LSD is really nice to have.
If you want torque, go with a H22.
The only reason I WOULDN'T do a H22 swap is if your car just had to have a/c and power steering. You can fit a/c in there if you try, though.
Its $1,000+ Cheaper than b-series swaps, more torque, and, in some cases, more horsepower.
There are certian things that are different with the H22, but, it's worth it if you ask me.
HOTek9
03-22-2003 10:58 PM
