ek clock install ??
ek clock install ??
i have a clock for my 96 hatch but no pig tail , i tried looking for A thread and no luck ... any one knows how or have a link ? thnks
Re: ek clock install ??
The amber clock from the SIR?
i've seen people hook those up to their stereo wiring
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/help-ek-amber-clock-installation-2361911/
https://honda-tech.com/forums/showthread.php?t=2361911
I used a spare harness from a dash that I had and used some clips form it and I figured out what wire is for dimmer , ignition , ground and so on .. Havent got my plug for the stereo tho
H-T White Ops
More than likely there is at least one SiR in one country that did have a dimmer.
Either way, the clocks I've seen come with that pin. It's just easier to make them all with it than to make two versions of the clock. Sort of like how my '88 HF is supposedly wired for a stock clock even though the HF didn't come with one (other trims did though) or how '92 Civics (so I hear) are pre-wired for VTEC even if they're not a trim that had it.
H-T White Ops
Oh, and if you can match the chart I had in the other thread to which corners you use, could you please let me know so I could include that info since not having a plug seems semi-common?
so hopefully this helps a few people since i didn't get no answer on line i did my own "plug" or "harness" i had a spare dash harness from an old dash so i de-pinned some wire with pins and searched for a pic of the plug (blue plug ) and i just followed the same chart NOFX had posted before , i wired it to stereo harness and there you go a working clock , i put some glue on the plugs so they won't come out or make contact with each other , sorry for the crappy cell pix
H-T White Ops
DaNnY871 told me in PM that he wants it before Christmas, which makes me think it might be a gift.
You can't order stuff like this thread Honda of America though. You'd have to get it from Europe and it'd be REALLY pricey through Honda (~$270-$460, I'm assuming this depends on color).
Buying from Europe also means you need to pay shipping and customs charges. Plus it will not be here by Christmas.
As far as I know, no other retailer lists this clock for sale because the part is just not that high in supply and demand. You just have to wait until a private seller or eBay shop puts one up for sale.
H-T White Ops
Remember there are different colors too (amber, green and I think white iirc).
Crazy Honda Guy
hmm, you sure the EL shares the same pigtail? It is in fact a "different" clock...i will double check this next time i hit up the wrecker. I have an extra EK4 clock also
no clue actually deetz was just suggesting another clock he could look for . what colour is your ek4 clock ?
H-T White Ops
I can tell you that the EK clock being talked about fits in the 1996-1998 Civic dash perfectly. The matte black bezel you see around it when mounted it actually part of the dash.
It sucks that in the US the radio is the only source of a clock... until you replace the radio with one that doesn't have a clock, but I personally enjoy parts that fit 100% perfectly, like they were made for the car.
Remove the center climate control bezel (the entire black thing that surrounds the radio and climate control and all). I don't remember the last time I had to get that out, but you might need to remove the radio to unbolt things, plus the panel under the dash/behind the cupholders. There's a screw behind the defrost button up top (pop it out GENTLY with a flathead - these buttons will easily chip) and another screw behind the emergency flasher button (remove it the same gentle way).
This entire thing should come out:
Remove the cubby from the passenger side of the bezel. Btw, the cubby is different from the EX versus the lower trims such as the CX with no radio. The EX iirc, has the two little holes where the radio would clip onto the cubby. The pic above is from a model with the factory radio because you can see the holes in the cubby. This is what I remember from my '98 EX and my friend's '97 CX at least.
The clock mounts with a screw in either side from the back of the climate control.
Pic of one installed:
http://carphotos.cardomain.com/ride_...0010_large.jpg
Just wire it in as described elsewhere and you should be good. I'd recommend making sure the one you buy has the pigtail. I'm not sure if anything else uses this same plug.
crxnatic
01-17-2012 05:19 PM
djpepsi
05-11-2007 05:06 PM
wu tang
01-16-2005 09:33 PM
