92 si b&m shifter droping down
hi i have a question i have a 92 si hb with a b&M shifter the one that has the blue Anadized collar the actual shifter has droped down i can still drive the car but the bottom of shifter is resting on the exhaust and has came out of the blue collar what has caused this and how do i fix it? thanks for any input
Re: 92 si b&m shifter droping down
there are two bolts and a bushing
Last edited by Former User; 12-13-2011 at 07:09 AM. Reason: Edited post. Warning - Make this your last asshat post in this tech forum.
dude i just had this same problem with mine. there is a thin coil washer looking thing that sits in a groove at the base of the shifter that bent out of shape. i went to lowes and bought a snap ring been good ever since. that was like a month back.
i miss the days when everyone was nice to each other and just tried to help.
Learn to limit your posts to technical remarks and to eliminate your sour side and we'll all get along better. Period.
this has to b the problem so its a snap ring sounds right because all of the bolts related to the shifter r there and are tight i have a 89 boosted b17a1 n a rex so i know pretty much how to work on the cars but never have come across this prob is why i asked thanks to the people that has tried to give advice thank you if i could fig out how to post pics to this i would put some up i will look for the correct place to talk bout that peace
yeah, your bushings can be bad too....do what First.EG said, i'm gonna try it as well since i'm having a little bit of vertical movement with my shifter.
hey thanks for the heads up i have had this shifter for a couple years in my crx but i made a custom one for the rex and put this in my si the bushings are all new when i put this shifter in car it has to have been a snap ring that has broken
b&m part#45074 is the shifter that i am talking about if i knew how to post the pic of it i would the blue collar holds the shifter up and has the bearings in it with a snap ring that holds the shifter up the snap ring broke on mine thank goodness i own a machine shop we have them all over shop thanks for the input guys i just never knew it was held in there by a snap ring
TwistedSI
04-07-2003 05:03 PM
phreaker
11-07-2002 08:46 PM
