EJ6 Build, SiR-Turbo
#101
Re: EJ6 Build, SiR-Turbo
Garrett 600 hp core I will be installing later. Debating on what clutch I will be using. Most likely candidate is a Twin Disc Comp Clutch Spec C. Also working out some other minor details before I get this engine back which I will post on here!
#104
yes have to use applicator gun becuase the two parts mix in the nozzle that attaches to it. It is 3m 8115 PBA. http://www.levineautoparts.com/3maupaboad20.html
#105
getting way behiind on things.
1. been looking at clutches still.
2. debating on 5 lug CTR swap (pretty sure im going to do it).
3. still no word from ERL.
4. need to install rear lower arm bar.
5. need to install pedal stop for what ever twin disc im going to use.
#108
the rear fuel cell in the trunk
nice build, quality parts, are you highering jajaja
clean build i have been debating ditchig my gas door as well and opting for a cell in my hatch nice build man keep it comming
#114
its linoleum. i actually just recently installed the same linoleum on his kitchen floor it turned out great. just make sure to rent the roller and let the glue get tacky and gasses out before laying the floor or it can get air bubbles trapped underneath if u rush it. nice build so far. i def know what your talking about with a real intercooler vs a ebay intercooler. my sparco intercooler is way more durable and not as cheap and thin as the ebay intercoolers.
#117
i definitely like the design of the new lid a lot better. im sure if u were picky u could use a dremel or some sand paper to smooth out the welds a lil bit. i've always heard welding aluminum is hard and must be super clean to leave a good bead. it's just a gas tank and its under the trunk hidden ..lol
#120
I wound up using Armstrong tiles from HomeDepot for my garage, came out nice but I like that better.
Congrats on the progress man, coming out nicely.
