Eg hatch stays on after key is removed
92 eg hatch with an ls swap stays on after I remove the key here a slight buzzing under the hood have to kill the car manually then disconnect the battery. Something is staying on and drawing power if I don't. Please help!
Re: Eg hatch stays on after key is removed
Previous owner had a kill switch I guess. Also turn signals don't work but hazards do. And the gauge cluster quit working
None that's the weird thing. Changed the ignition harness cuz that's what I thought could be wrong changed the cluster. Thought it was the fuel pump hard wired
I thought that might have been the problem but it doesn't run. I guess I'll just start testing every wire and go from there
also pull your starter and and test it. could be a short in it... if the starter is fine, then you could have a short, bad ground, blown fuse, anything
Austinsharp73
03-13-2019 10:10 PM
EGhachiback
12
06-11-2014 03:44 AM
93grayeg
10-16-2009 02:07 PM
Honda Virgin
06-02-2004 12:34 PM
jdmcivicferio
41
01-14-2003 12:45 PM
