EG hatch rear interior question
does anyone know wat kind of rear interior will fit the eg hatch w/o any modifications? or do i have to stay w/ stock rear interior or just wrapp the seats...
Re: EG hatch rear interior question (nongk)
Do a Search for "seats" in the EG+ Civic / Del Sol forum. Prepare to be overwhelmed with knowledgeable information
Your question makes no sense. And when you sear for "seats" in EG+ absolutely nothing about rear seats comes up. Are just talking about doing a rear seat swap or what? For real seats you can do any Teg seats, no sure bout what else. As for the rest of the rear all you can really do is a JDM SiR interior. (If you do the SiR interior you cannot have Teg seats, you must SiR rear seats, usually included in the rear interior.)
-Jake
-Jake
Teg upper rear parts of the seats can bolt right up, the bottom part is a little too small for the civic chassy, but wiht a little modification will work out fine, and look pretty decent. Teg seats are a good option if your looking for either a leather touch, or a black interior from an teg. The only other option is have your factory seats recovered to your liking. Hopes that helps
The seatbacks from a GS-R coupe will bolt right in, but the cushion will not. Although it will "sit" in place, the bolt hole used to attach the cushion to the car is on the opposite side of the loop in the seat and the metal tabs at the leading edge of the seat don't line up with the holes in the car. I've heard a GS-R 4 door cushion bolts in, but I've yet to try that. For now I just have the cushion held in place by bucking the rear seat belts.
ZEAL-SPORTS
05-07-2006 08:40 PM
