eg hatch fuel pump
eg hatch fuel pump
car is a 94 eg hatch with a b18c and chipped p28
the fuel pump will not prime when i turn the key
i jumped pin 1 and 7 on the main relay and itll prime but not when i jump 1 and 5.
already replaced all fuses and checked thermostat ground
Re: eg hatch fuel pump
Does the check engine light stay on solid....if so...you have an ecu problem....
It should turn on for 3-4 seconds when you turn the key on and then turn off...if it's staying on solid....you may want to try anthoer ecu....esspecially since yours is chipped...
RichCMemphis
03-03-2014 06:16 PM
XxfatlacexX808
02-01-2013 05:19 PM
sebastianaleman
12-15-2011 04:45 AM
