EG Front Swaybar??
EG Front Swaybar??
I'm wondering whether the front swaybar from the ITR is compatible with the EG chassis. Has anyone thrown one of these on? I'm not gonna lie, I really haven't researched this topic too thoroughly , but what is the factory swaybar size on a Civic Si hatchback? If it is possible to throw on the ITR swaybar, is anything else required, or can the stock bolts (and whatever other equipment) from the Civic Si hatchback be used?
Thanks!
Thanks!
Re: EG Front Swaybar?? (Creepsjr)
Yes, I had a GSR/ITR 24mm front sway bar on my 92 hatch. All you need are LCAs that are compatible with the mounting of the endlinks (ie 92-95 Si, EX, LX or 94-01 Integra) and all the hardware associated with the sway bar (bushings x2, bolts x2, nuts x4 [to mount endlink to LCA and to mount d-bracket to LCA], d-brackets x2, endlinks x2).
The stock Si front sway bar is 21mm I believe.
Lordofdark176
07-27-2009 03:10 PM
litterbox
05-10-2004 08:14 PM
hatchy
14
07-09-2002 04:53 PM
