EG Daytime Running Lights Problems?
Old 01-25-2004, 05:48 AM
93jdmr's Avatar
Default EG Daytime Running Lights Problems?
I had a situation recently that my autometer water temp was connected into my drl and when i tried to disable the lights by removing the fuse the gauge would stop working also. So i instead took out the drl box in the engine compartment located near the drivers side clutch canister. Would that disable the drl also instead of pulling the fuse?
Old 01-25-2004, 01:12 PM
93jdmr's Avatar
Default Re: EG Daytime Running Lights Problems? (93jdmr)
up
Old 01-25-2004, 01:22 PM
NonovUrbizniz's Avatar
You said you removed it right?
So are they on or off?
That should answer your question...
But removing the box should certainly disable them as it contains the power from the fuse box and the neccisary relays/resistors to turn them on with acc. power.
Old 01-25-2004, 01:44 PM
93jdmr's Avatar
Default Re: EG Daytime Running Lights Problems? (NonovUrbizniz)
i did remove it, but cant check yet because my front clip is off. But since i removed it, it shoudl disable (not work anymore) exept when i turn on my headlights with the control right?
Old 01-25-2004, 02:00 PM
SikofFalln's Avatar
Use a DMM, that should tell you if it worked or not.
Old 01-25-2004, 02:06 PM
93jdmr's Avatar
Default Re: EG Daytime Running Lights Problems? (BseriesPWR)
whats a DMM?
In The Garage
Shawn C's Avatar
why did you hook the autometer watertemp gauge to the DRLs?
Old 01-25-2004, 02:29 PM
93jdmr's Avatar
Default Re: (ShadyEH2)
i didnt hook it up, i got the car like that and only realized it when i went to pull out the drl fuse and noticed the gauge didnt work
Old 01-25-2004, 02:39 PM
TurboBumblBee's Avatar
why dont you just wire the guage the correct way?
Old 01-25-2004, 03:09 PM
93jdmr's Avatar
Default Re: EG Daytime Running Lights Problems? (Hybrid95CivicEX)
Since i took out the drl box, if that works its much easier leaving it wired it up that way and just removing the box since it just plugs it and is held on by a 10mm bolt.
Old 01-25-2004, 04:21 PM
SikofFalln's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93jdmr &raquo;</TD></TR><TR><TD CLASS="quote">whats a DMM?</TD></TR></TABLE>
Digital Mulit Meter
Old 01-26-2004, 08:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz &raquo;</TD></TR><TR><TD CLASS="quote">But removing the box should certainly disable them as it contains the power from the fuse box and the neccisary relays/resistors to turn them on with acc. power.</TD></TR></TABLE>
But then again it may also be the only power source to the headlights... So it may dis-able your headlights... Frankly I'm not sure. I'll check my helms when I get a chance.
Dkahn18
06-20-2010 09:32 AM
90crxdxb16
11-05-2006 07:11 PM
98IntegraLSNonVtec
02-24-2006 10:07 PM
rhdins
01-31-2006 12:52 PM
Quick Reply: EG Daytime Running Lights Problems?
