EG cluster question
EG cluster question
i just converted my crx over to use an EG cluster. what are the small yellow and the small green plug on the back of an EG cluster? abs? srs?
Location: hittin corners so hard you can taste my rims..
Re: EG cluster question (xDEFTONESx)
the yellow is deff.. SRS.. and im 90% sure the green was VSS. vehical speed sensor.
so if you put a EG cluster in your CRX.. im not sure how your going to get that cable tranny to input a speed into an electoronic cluster....?
do a search.. ive done it (in a CRX, going from USDM, to JDM EF8 gauge cluster), and countless others in upgrading, or swaping a cable speed sensor into a electronic sensor.
Modified by Built B16A at 11:50 PM 1/20/2007
Re: EG cluster question (Built B16A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A »</TD></TR><TR><TD CLASS="quote">the yellow is deff.. SRS.. and im 90% sure the green was VSS. vehical speed sensor.
do a search.. ive done it, and countless others in upgrading, or swaping a cable speed sensor into a electronic sensor.</TD></TR></TABLE>
ok so im going to throw the yellwo one away.
the greeen IS NOT vss. that is wired into the 12 pin plug.
i made the cable tranny work with the electronic VSS by inserting a electronic VSS into my cable tranny and wiring the VSS into my wiring harness.
so what is the green one for sure? i got this out of a 95 coupe with 4 wheel disk and abs so im thinking it is an ex-s. its a 9K rpm tach
well for starters there is no such thing as an "ex-s" i thin the green plug has to be for cruise control
green is maybe seatbelt cause the green is missing from my CX cluster and it has no seatbelt alarm. (there is also nothing to connect to the seatbelt thing under the driver seat too so that's why I think that) The yellow is SRS cause I was Monkeying with my EG cluster in my EK and plugged in the yellow to the EG cluster and Yes it's SRS.
*edit maybe cruise cause obviously my CX has no cruise either. Also EG and EK clusters both have the Green and Yellow (for the ones that have whatever the green one goes to) so I can compare my EK.
Re: EG cluster question (2DoorBandit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2DoorBandit »</TD></TR><TR><TD CLASS="quote">well for starters there is no such thing as an "ex-s" i thin the green plug has to be for cruise control</TD></TR></TABLE>
then what is a black on black civic ex with 4 wheel disc and abs? i could have sworn they had an "s" designator
Re: EG cluster question (bpr0422)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 »</TD></TR><TR><TD CLASS="quote">the green,
is the cruise or shift up indicator cirucit</TD></TR></TABLE>
ok. so the short simple answer in my particular case is to ust throw them away.
now i have anotehr question that will take someone knowledgable.
one of the wires in the eg cluster pinout is labled "hot"
wtf? it isnt "power". i got those.
Firefoxracer
12-17-2006 09:20 PM
