EG guage cluster swap
Old 03-29-2005, 06:38 AM
bravoecho11's Avatar
Default EG guage cluster swap
Any one ever put a EK guage cluset in a EG? if so post up some pictures.
Old 04-05-2005, 05:28 AM
Default Re: EG guage cluster swap (bravoecho11)
anyone?
Old 04-05-2005, 05:34 AM
Imperious: Mod of Valor
JDM-EJ1's Avatar
I'm sure it's been done, I'm guessing it's there the same shape about. Although I'm not sure about the plugs in the back, if they would match up. I'm sure it's been done though, just search around.
I like the EG clusters more anyways.
Old 04-05-2005, 05:40 AM
wdwalker's Avatar
Default Re: EG guage cluster swap (JDM-EJ1)
i put an integra cluster in mine, so i'm sure it'll work, any cluster will work so long as they are using a mechanical speed sensor... course i did see an eg hatch with a rsx dash/cluster, don't know how the hell he wired that bitch up, it uses like its own ecu to power the dash lol.
Old 04-05-2005, 05:42 AM
JDM-EJ1's Avatar
Default Re: EG guage cluster swap (wdwalker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wdwalker &raquo;</TD></TR><TR><TD CLASS="quote">i put an integra cluster in mine, so i'm sure it'll work, any cluster will work so long as they are using a mechanical speed sensor... course i did see an eg hatch with a rsx dash/cluster, don't know how the hell he wired that bitch up, it uses like its own ecu to power the dash lol.</TD></TR></TABLE>
Wow, that's something else. Yeah, EK cluster in an EG should be pretty straight foward procedure. Shouldn't be that difficult.
Old 04-05-2005, 05:50 AM
MeanD's Avatar
i just did the Ek cluster into my car and it wasnt to bad you have to trim alittle of the bezel to get it to fit right. You are going to need a wireing diagram for both EG and EK cluster and also you need the plugs to make it work you only have to worry about the two big plugs the other two work just fine. when you get the diagrams just match up the wires to ther significant counter part and boom your done. the only draw back is that the cluster doesnt fit all that great i am going to make a new bezel to make up for the gaps. Well good luck with it.
Old 04-05-2005, 06:16 AM
JDM-EJ1's Avatar
Default Re: EG guage cluster swap (MeanD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanD &raquo;</TD></TR><TR><TD CLASS="quote">i just did the Ek cluster into my car and it wasnt to bad you have to trim alittle of the bezel to get it to fit right. You are going to need a wireing diagram for both EG and EK cluster and also you need the plugs to make it work you only have to worry about the two big plugs the other two work just fine. when you get the diagrams just match up the wires to ther significant counter part and boom your done. the only draw back is that the cluster doesnt fit all that great i am going to make a new bezel to make up for the gaps. Well good luck with it.</TD></TR></TABLE>
The hardest part to me would be mapping out the wires and what not, and espically in such a small area like that. Ahh, I hate doing stuff like that.
SiBlueEG6
09-04-2009 07:25 AM
jadugartir
10-09-2006 07:42 PM
BubLBack
12
09-07-2006 09:23 PM
Neiser
11
01-26-2006 04:11 AM
Quick Reply: EG guage cluster swap
