EG with cable tranny, which VSS?
The swap I'm dropping in the EG comes with a cable S1 tranny. Just wondering which VSS can be use for this application.
Re: EG with cable tranny, which VSS? (beelzebub)
you want to put the electronic VSS from your old tranny into the cable one. Not to mention you'll have to adapt the hydrolic clutch to work with teh cable tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beelzebub »</TD></TR><TR><TD CLASS="quote">The swap I'm dropping in the EG comes with a cable S1 tranny. Just wondering which VSS can be use for this application.</TD></TR></TABLE>
why ???? just stick with the hydrualic tranny
cable tranny's blow
cable tranny's blow
I cursed out BauleyCivic and got banned
Re: EG with cable tranny, which VSS? (CALIdelsolSIR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SonicGSR98 »</TD></TR><TR><TD CLASS="quote">you want to put the electronic VSS from your old tranny into the cable one. Not to mention you'll have to adapt the hydrolic clutch to work with teh cable tranny.</TD></TR></TABLE>
y not just get a cable pedal assymbly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CALIdelsolSIR »</TD></TR><TR><TD CLASS="quote">why ???? just stick with the hydrualic tranny
cable tranny's blow </TD></TR></TABLE>
whats the basis on that remark? i personally like cable clutch cuz its in or out instead of play like hydrolic............also u dont need to keep refilling the fluid and u dont need to flush the fluid..........i work at an dealaership and i know how much of a b!tch it is to flush the clutch res............
Re: EG with cable tranny, which VSS? (96accordlxf22b2)
Well, I would love to get a B-series hydro tranny, but everyone wants an arm and a leg for it. Picked up an S1 cable tranny (which by the way has similiar gearing to an ITR except for 4.4 final drive) with Hasport hydro to cable conversion for under $400 shipped. The swap's going into an EG and it's missing the VSS.
Just wanted to clarify before I go out searching for one.
Re: EG with cable tranny, which VSS? (SonicGSR98)
So just stick to the stock VSS that came in the car is what your saying. Would it bolt right up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SonicGSR98 »</TD></TR><TR><TD CLASS="quote">yes, it will bolt right in, but what are you going to do about the cable clutch?</TD></TR></TABLE>
The cable tranny came with a Hasport hydro to cable mount and conversion kit. At this point, I'll have to use 90-91 Integra clutch, axles and midshaft. Thanks for the input!
onetwothreelookatme
05-06-2004 11:21 PM
