Will coil overs from a 93 eg fit on a 96 ek?
Old 01-20-2012, 03:28 PM
jayscivi's Avatar
Default Will coil overs from a 93 eg fit on a 96 ek?
Will a set of coil overs off of a 1993 eg fit on a 96 ek
Old 01-20-2012, 03:30 PM
jserman's Avatar
Default Re: Coil overs for an ek
yes
Old 01-20-2012, 07:07 PM
racerx510's Avatar
what he said
Old 01-20-2012, 07:35 PM
rayvo's Avatar
yes they will fit, the rear will just need spacers on inside of the lower strut fork...
Old 01-20-2012, 08:16 PM
Master Detailer
98civdx's Avatar
^ That is only if the coilovers came with shocks, he could just be talking about slip ons.
Old 01-20-2012, 09:05 PM
dwkt's Avatar
EK LCA bushings are thinner than the LCA bushings on an EG so if you remove the coils from an eg and put them on an EK you will need the spacers for the rears. they look like thick washers and can probably order then from any shop, I know skunk2 sells them.
if you are just talking about sleeves then Ive wasted my time telling you about the LCA's and you are good to go.
Old 01-24-2012, 01:45 PM
jayscivi's Avatar
Default Re: Will coil overs from a 93 eg fit on a 96 ek?
I only have springs and the adjuster no shock or anything
Old 01-24-2012, 01:47 PM
jayscivi's Avatar
Also I coul use a good instructional video on how to do this because I am doing this tomorrow night
The Grumpiest
grumblemarc's Avatar
What brand of coilover and what shock is it going on?
Old 01-24-2012, 09:14 PM
jayscivi's Avatar
The brand is cla and there going on the stock civic shock thAts on the car now
Old 01-24-2012, 09:23 PM
eg62012's Avatar
yes they will
Old 01-24-2012, 10:11 PM
Master Detailer
98civdx's Avatar
CLA? WTF is that?
Good luck, your going to have a very bouncy car.
Old 01-25-2012, 04:02 AM
The Grumpiest
CLA=Ebay.
Old 01-25-2012, 07:16 AM
Red_Army's Avatar
well...don't do that.
or this will become how do i fix my blown shocks thread.
Old 01-25-2012, 07:34 AM
delsolo95's Avatar
lol so true!
Old 01-25-2012, 07:45 AM
jayscivi's Avatar
What
Old 01-25-2012, 07:51 AM
The Grumpiest
Coilover sleeves + stock shocks = Blown stock shocks.
Old 01-25-2012, 08:11 AM
jayscivi's Avatar
How does that work ? How will they blow
Old 01-25-2012, 08:19 AM
MonkeyBoy668's Avatar
Because the stock shocks are designed to work at stock heights and running them at lower heights damages them, eventually leading to permanent damage (AKA blown shocks). When you lower the shock you increase the amount of pressure in the tube, constantly running at high pressure causes a blowout because they're not designed to run at high pressure all the time.
Old 01-25-2012, 10:36 AM
Master Detailer
98civdx's Avatar
Don't forget spring rates.
OP, do you even know what the spring rates of the coilovers are?
Old 01-26-2012, 09:59 AM
509ernie's Avatar
Monkeyboy668 is right after a while your car will be bouncy as f**k
pleej
Suspension & Brakes
02-12-2010 08:27 AM
da6er
Suspension & Brakes
04-09-2008 12:54 PM
Richie B
Suspension & Brakes
07-31-2006 07:40 PM
vizsual00
24
05-26-2004 10:09 PM
liam821
08-03-2003 01:22 AM
Quick Reply: Will coil overs from a 93 eg fit on a 96 ek?
