eg axles other ???????s
will integra b series axles work in 94 hb b16 about vtec can i use my 95 ex civic wiring harnes so i dont have to worry about vtec or do i have to wire vtec in the 94 hb wiring harness
Re: eg axles other ???????s
Yes on the axles. You can use the EX harness, but you'll still need to wire VTEC from the shock tower plug to the ECU; basically it will only be wired half way. Only '92-'95 Civics that came stock with VTEC engines, and all '92 Civics came pre-wired for VTEC from that connector to the ECU. Since your car is a '94, and I'm assuming didn't come with a VTEC engine, you will need to wire it.
http://www.ff-squad.com/tech/wiring/...ktowerplug.jpg
ecksman
11-26-2006 05:07 PM
