eg auto to manual swap using stock manual mount
I picked up a 93 automatic sedan shell to use whenever my dd car will be down for work. I have a full manual d16 and I know that you are suppose to use an aftermarket mount designed for the swap bc the welded bracket is different. However I don't care about this car much so is it possible to use the oem manual mount? I don't care if the engine sits higher on that side. I just want to know if it will work until I have extra cash for that mount. Only those who have attempted this exact move should chime in; no hearsay. TIA
Re: eg auto to manual swap using stock manual mount (6shootahorsenamedtrigga)
If you use a stock mount itll sit crooked and can cause axle failure. I wouldnt do it.
Re: eg auto to manual swap using stock manual mount (vestalfootball72)
yeah ive done that with the oem bracket on a different car and wanted to avoid that...
but it will def cause axle failure? is this from experience or what
when i did mine i tried shims but it still never sat right so i just drilled out the spot welds and put in a manual mount always heard axles when i shimmed when turning
Re: eg auto to manual swap using stock manual mount (borenshoratius)
hey thanks for that input..i was actually thinking about something like that...longer studs if need be and use a nut as a shim to lower the motor... when the axle made noise did it ever end up breaking...cuz this would just be temporary until i can afford that swap mount
Jason913
29
12-27-2011 07:48 AM
elmejor
06-18-2008 07:04 PM
lazymbf
10
06-06-2008 06:59 PM
getnasty
11-17-2005 12:56 PM
