ECU'S WHICH ONE!!!!
ECU'S WHICH ONE!!!!
ok so im putting my turbo kit together and im stuck on my injectors or my ecu so which ecu do you guys think is the best hondata, crome. or uberdata, im soo confused on which one to get, by the way its a d16y8 with 7psi. and injectors which ones and size and what is a resistor box, please help. thanks guys
Re: ECU'S WHICH ONE!!!! (stock ek)
First of all hondata, crome, and uberdata are different programs for tuning an obd1 ecu. They are not each a kind of ecu. To use any of those, you will need an obd1 ecu...for your situation you will want a p28 ecu which came off of the 92-95 ex civics. You will also need an obd2 - obd1 conversion harness. From there you will need to get it chipped with a basemap for your situation, and then baby your car all the way to your tuner who will set you up.
otakueric
10
05-22-2004 06:07 PM
